Ruby.Array.Problem.(Solved)
Look to the file.
Ruby.Array.Problem..fsm- (1.22 KiB) Downloaded 827 times
I hope my english was understeandable.
Skype id - parkidesu
Parki - Posts: 20
Re: Ruby.Array.Problem.
use .push or << to append an array
http://ruby-doc.org/core-2.2.0/Array.ht ... od-i-3C-3C
I won't be rude but...
Any work code which add an array to array?
Parki - Posts: 20
you can find all you can do with arrays in the link above
http://ruby-doc.org/core-2.2.0/Array.html#method-i-2B
to add an array to another just "add" them,
so if you want to add arrayB to arrayA:
arrayA = arrayA + arrayB
or shorter
arrayA += arrayB
or shorter
arrayA += arrayB
Nubeat7 wrote:http://ruby-doc.org/core-2.2.0/Array.html#method-i-2B
I propose to link to core 1.9.3 instead, because that's what Flowstone uses. It has no influence on this particular question, since nothing has changed for arrays. But this might not always be the case.
I almost pray for it would be last.
5.fsm- (1.19 KiB) Downloaded 809 times
Parki - Posts: 20
Take a look at this:
- TheOm
Thank you guys for your help me with my idiotic problems with syntax.
Parki - Posts: 20
