bridge and flowstone
Hello,
What I noticed is?
New compiled stuff from flowstone, is not recognized by Briding softwares, or there are some modules which cause them but old compiled plugins work perfectly. I did make work lot of my compiled stuff and this theory actually worked in bridging in ableton 9 live probably im incorrect since im not into coding stuff any more..... Professionals can test the theory
What I noticed is?
- mrking
Re: bridge and flowstone
What versions exactly are you using for export? Are you using internally identical projects or different projects?
- Perfect Human Interface
also intrested in those problems. Also had problems with jbridge on 3.06
- djbrynte
my few compiled plugins were in 3.0.2 , so that is how I got the idea, it's probably new development or experimental modules which are not recognized by bridging software as genuine vst.
But like I said, my old compiled plugins worked in 64 bit host ableton on 64 bit machine. But my new compiled stuff didn't work. Also there is a free plugin may be my MY-CO or something like this, his saturation compiled from old 3.0.2 also worked perfectly.
ALSO I WILL TEST THE THEORY, I WILL COMPILE FEW PLUGINS WITH OLD SYNTHMAKER and Flowstone initial version today.
- mrking
