Ring Mod gives a diffrent octave?
Postby djbrynte » Fri Mar 13, 2015 4:30 pm
streamin in1;
streamin in2;
streamin mix;
streamout out;
out = mix*(in1*in2 - in1) + in1;
I have this code for ring mod. And when i use ring mod on another osc so i use 2 ring mods then this oscilator gets another pitch.
djbrynte
Re: Ring Mod gives a diffrent octave?
Postby djbrynte » Fri Mar 13, 2015 5:06 pm
the error can also be in this code.
streamin in;
streamin volctl;
streamin vol3;
streamin vol1234;
streamout out;
float F1=1;
float F0=0;
float FP5=0.5;
movaps xmm0,vol3;
addps xmm0,vol1234;
mulps xmm0,FP5;
minps xmm0,F1;
maxps xmm0,F0;
mulps xmm0,in;
mulps xmm0,volctl;
movaps out,xmm0;
djbrynte
Postby Perfect Human Interface » Fri Mar 13, 2015 7:05 pm
That's what ring mod does. The original frequency content, including the fundamental, is gone in ring modulation.
In ring modulation, the resulting signal frequencies are the sum and difference of the source signal frequencies. The original frequencies are not preserved. If you want them to be preserved, that's amplitude modulation.
Ring modulation is simply Signal A * Signal B. Amplitude modulation is Signal A * (Signal B + 1) <--(all values are positive)
Postby djbrynte » Fri Mar 13, 2015 7:15 pm
Mybe u can help me have a look. I have ring mod on osc 1 osc3 and osc 6. But the normal octave is diffrent on osc 3 and 6. The rest is the same tune. There is strange problem. So the tune is changed on osc3 and Osc6 when ring mod is off.
djbrynte
Postby djbrynte » Sat Mar 14, 2015 8:57 pm
i fixed it.
djbrynte
