I got a question for you.
Postby tor » Tue Apr 14, 2015 12:11 am
Looooong time, no see. I have not been logged on here for ages.
I am concidering to make an automation system for beer breewing with Flowstone and Phidgets. How well does Flowstone work on Windows 8.1 64 bit? How well does exported exe's work on similiar? I have to know this before I consider to upgrade from SM to FS.
tor
Re: I got a question for you.
Postby martinvicanek » Tue Apr 14, 2015 8:20 am
Hi tor,
I am using a Win 8.1 tablet as my virtual bass effects rack. It runs an exe exported from FS. Works well. It is a 32 Bit Windows though.
Postby tester » Tue Apr 14, 2015 2:10 pm
32bit apps work normally on 64bit win81. The only thing you have to remember - even if you have a lot of memory, 32bit apps will reside in the range of less than 4GB.
Postby nix » Tue Apr 28, 2015 12:59 pm
I can't vouch for the .exe s,
but the application itself runs fine I think
I'm on 8.1 x64 on this lappy
nix
Postby fixstuff555 » Wed Apr 29, 2015 10:32 pm
For what it's worth, I use 8.1 64 bit, and have exported exe's to both XP and 7 with no problems. This is using 3.07 though.
fixstuff555
Postby Rocko » Thu Dec 01, 2016 7:41 pm
Hi
Was always interested in virtual bass algo's. Whats the signal chain of these? Filter (out the bass) then add harmonics as a function of input level and add back the high frequency? Is that the main thing here?
Rocko
