Mem address crash discussion (split from DSP code 2)
Postby Youlean » Sat Apr 11, 2015 11:05 pm
Here is DLL for mem creating. I hope that it works. I am not sure if it gives accurate address tho... Please test it...
Try optimized version first, it is not working, than try normal version...
Mem Adress (Optimized).fsm
(4.44 KiB) Downloaded 855 times
Mem Adress 2.fsm
(10.06 KiB) Downloaded 860 times
Youlean
Re: Custom DSP Code 2 (comunity project)
Postby KG_is_back » Sun Apr 12, 2015 12:07 am
Youlean wrote:Here is DLL for mem creating. I hope that it works. I am not sure if it gives accurate address tho... Please test it...
Both only output the mem size, but not address.
Postby Youlean » Sun Apr 12, 2015 12:17 am
You mean input equal to output?
Try locating DLL manually...
Mem Address.zip
(4.82 KiB) Downloaded 874 times
Youlean
Postby Tronic » Sun Apr 12, 2015 10:05 am
To have a correct memory address from a DLL,
in the manual there is a hidden information between words,
when you create an input and output to the DLL component,
FlowStone automatically assigns a memory address based on the type specified,
so just catch and use the pointer addresses, and output them as a list,
this gives us the opportunity to have as many memories as you want and the correct type,
just increasing the inputs to the module DLL,
with this I am able to write and read in the DLL memory without using any link to it.
Tronic
Postby Youlean » Sat Apr 18, 2015 4:59 pm
Hey, I think that this should now be working correctly...
If it works now, please report. Thanks.
Mem Address Final.zip
(81.24 KiB) Downloaded 859 times
Youlean
Postby Tronic » Sat Apr 18, 2015 6:26 pm
as mentioned above, you do not need to have a Frame to Mono and vice versa, you can just created into the DLL, an NEWFLOATARRAY, get the pointer, and output it as integer value.
Tronic
Postby Youlean » Sat Apr 18, 2015 6:32 pm
Tronic wrote:as mentioned above, you do not need to have a Frame to Mono and vice versa, you can just created into the DLL, an NEWFLOATARRAY, get the pointer, and output it as integer value.
Yes, but than you can't change it's size. The size must be then hard coded.
Youlean
Postby Tronic » Sat Apr 18, 2015 8:02 pm
you can assign the size with an external value,
for already created array just copy the old content and recreate it with different sizes.
Tronic
Postby Youlean » Sat Apr 18, 2015 8:11 pm
Tronic wrote:you can assign the size with an external value,
Tronic, either you or me is not getting the point here.
If you want to create mem, just use mem create primitive, but KG asked for mem creation to give address at stream speed which need mono to frame if you want to do it with dll...
Youlean
Postby Tronic » Sat Apr 18, 2015 8:19 pm
The memory address has nothing to do with the stream speed, it is only a pointer to the heap.
Excuse me if I insist, but your code only wastes resources, to process an empty buffer,
even if you emit only poiter memory.
So the point is, why have the value of a pointer to memory, at stream speed?
Edit: the mem create primitive, have some problem with alignment when retriggered.
Tronic
