Int Array Help
Int Array Help
Postby TrojakEW » Sun Apr 26, 2015 5:56 pm
Hello guys. Can somebody help me with small problem? I need to swap values in integer arrays. I know ho to easilly do this in ruby but i need solution with green primitives since i dont want to use ruby at all.
I need this for module/effect ordering. So for example I have array with six integers 0,1,2,3,4,5 and i need to swap two choosen values. For example 0 with 3. I have tried to do it by myself but no good working soluton.
TrojakEW
Re: Int Array Help
Postby Exo » Sun Apr 26, 2015 7:10 pm
Inside the Developer toolkit in the Array section is a "Sort integer array" module, have a look at that it uses swapping to sort the array. Maybe you can learn from or modify it for your needs.
Exo
Re: Int Array Help
Postby Youlean » Sun Apr 26, 2015 11:36 pm
Here you go...
Swap.fsm
(433 Bytes) Downloaded 812 times
Youlean
Re: Int Array Help
Postby TrojakEW » Mon Apr 27, 2015 7:21 am
Thanks you guys. I will check booth and see what is best for me.
TrojakEW
Re: Int Array Help
Postby TrojakEW » Tue Apr 28, 2015 9:07 pm
Well I found the same problem in booth version and in my own attempt too while swaping the array. Problem is when I want to use array from output again for another swap. Look in attached file - I used Yoleen example. Try to change index few time and you will see the problem. It will add same value to two indexes after 2 or more changes. How to fix that?
Swap_loop.fsm
(488 Bytes) Downloaded 816 times
TrojakEW
Re: Int Array Help
Postby martinvicanek » Wed Apr 29, 2015 8:55 am
Hmm, perhaps a trigger order issue? Here is an alternative using code instead of green.
SwapIntArray.fsm
(766 Bytes) Downloaded 850 times
Re: Int Array Help
Postby Nubeat7 » Wed Apr 29, 2015 12:11 pm
here is a green version which should work correct
Swap_array_elements_green.fsm
(578 Bytes) Downloaded 811 times
Re: Int Array Help
Postby Youlean » Wed Apr 29, 2015 10:30 pm
This should work correctly now in loop.
Swap V2.fsm
(486 Bytes) Downloaded 814 times
Youlean
Re: Int Array Help
Postby TrojakEW » Thu Apr 30, 2015 10:26 am
Thanks. Going to test them today.
TrojakEW
Re: Int Array Help
Postby MyCo » Thu Apr 30, 2015 11:41 am
My version is quite similar to Nubeat7's...
Swap (MyCo).fsm
(1.24 KiB) Downloaded 794 times
MyCo
