Preset Manager question
Postby Logado » Sat May 02, 2015 2:33 pm
It's possible delete preset or swap two preset location, using default preset manager?
Logado
Re: Preset Manager question
Postby primate » Thu May 14, 2015 11:10 am
Hi!
if you mean change the order that they appear in the list in the DAW then i believe that going into the preset manager and adding a true value input to the 'order' variable on the primitive will result in the saved program file having a -1 value associated with each preset in the txt file that it saves. you can then edit the text file of the preset to change the -1 to the order number, resave the txt and reload it as a preset.
primate
