Edit Box - Set not editable
Postby Nowhk » Thu May 14, 2015 1:30 pm
Is there a way to put Edit Boxes devices not editable? I can put the mouse, delete and write what I want. I'd like to avoid this...
Nowhk
Re: Edit Box - Set not editable
Postby Nubeat7 » Thu May 14, 2015 1:48 pm
use a label then, or block any mouse action
Postby Nowhk » Thu May 14, 2015 2:06 pm
Label has not S pin input. How would you block mouse action? This is not enough:
Nowhk
Postby Nubeat7 » Thu May 14, 2015 2:09 pm
Nowhk wrote:Label has not S pin input..
just create one with "i" on your keyboard ;)
maybe it would be good to read the manual (page 63)
Postby Nowhk » Thu May 14, 2015 2:43 pm
Oh, I can use "I" for every element! Nice ;) Didn't noticed this. Thanks!
Unfortunatly I can't set a background, but I'll use a "back" image behind the label.
Nowhk
Postby Perfect Human Interface » Thu May 14, 2015 11:11 pm
Nowhk wrote:Unfortunatly I can't set a background, but I'll use a "back" image behind the label.
Use a "filled rectangle" prim and wire the view from the MGUI and the area (use "view to area") and a "colour" prim to the inputs. Make sure the order of the view connections is correct so that you don't draw the rectangle on top of the text.
