accurate VST host syncing / receiving MIDI clock
Postby airelibre » Fri May 29, 2015 6:07 pm
Hello.
I'm trying to make some kind of modular sequencer, working now on two basic modules, one to send different interval triggers, and a modulation one (envelope transformable to an LFO).
So far I've tried my basic designs using an Arturia Beatstep sending 1/32 notes, which I use as clock, but ideally I would need either:
a- Sync from host
or
b- Be able to recieve MIDI clock from one of my ext. hard (Some candidates are Beatstep or Kaossilator PRO+)
I've read this post, but it is a bit old viewtopic.php?f=3&t=1267
What's the current state of the art for ACCURATE Syncing to a VST host / Receiving MIDI clock ??? :D
THANKS !!!
airelibre
Re: accurate VST host syncing / receiving MIDI clock
Postby Nubeat7 » Fri May 29, 2015 9:20 pm
if you need it to create midinotes binded to host songposition there is no existing good solution, the thread you had a look is the best way to do it... a dll in c++ would be faster but no-one shared anything like this yet..
but you can have a look at nix' dreamsequencer here:
viewtopic.php?f=3&t=3446
if you need it to sync LFo's or stepsequencers... you can have a look here:
viewtopic.php?f=3&t=2732&hilit=ppq+synced&start=30
the thread is a bit chaotic but i know that the one i posted on page 4 works fine and right
you also can have a look at the psoition synced steplfo here:
(just updated and cleaned up the thread to have no old versions there)
viewtopic.php?f=3&t=1001
Postby Perfect Human Interface » Sun May 31, 2015 1:15 am
MIDI aside, there is a PPQ primitive that's synced to a DAW's PPQ position. Avoid green data and stick to stream data for anything you want to be sample/timing accurate.
