key follow formula
key follow formula
Postby Logado » Wed Jun 10, 2015 12:45 pm
Can somebody tell formula.
I thought that there just pitch multiplied by the coefficient. But I began to compare realized that there a little more complex.
Logado
Re: key follow formula
Postby tulamide » Wed Jun 10, 2015 2:23 pm
Key follow means, that, for example, a filter will adjust its cutoff according to the octave steps from the reference note.
Mostly the reference note is middle C, so if a note plays 1 octave higher (and key follow is at 100%) the filter will open up to double the cutoff frequency.
reference is C3, note played is C4, lowpass is set to 1 kHz, follow key is at 100% --> the filter will open up to 2kHz
reference is C3, note played is C2, lowpass is set to 1 kHz, follow key is at 100% --> the filter will open up to 500 Hz
reference is C3, note played is F#2, lowpass is set to 1 kHz, follow key is at 100% --> the filter will open up to 1.5 kHz
That said, and if pitch is the midi note number, it should work with
cutoff + ((pitch - 60) / 12 * cutoff * fkdepth)
where fkdepth is a percentage value in the range [0, 1], for the strength of the follow key function
Postby Logado » Wed Jun 10, 2015 2:31 pm
thank you, understood
Logado
Postby tulamide » Sun Jun 14, 2015 1:52 pm
Hey Logado,
I made a big mistake (that also nobody else seem to have noticed). It leads to the change being made absolute rather than relative!
Here is the corrected, relative version:
cutoff = 1000      #a cutoff frequency like from a filter
reference = 60.0   #To what midi note does the function refer to (middle c = 60)
pitch = 60.0      #The current pitch as midi note
fkdepth = 1.0      #The strength of the follow-key-function
f = 0.0
oct = (pitch / 12.0) - (reference / 12)
if oct < 0
   f = 1 / (oct.abs * 2)
elsif oct == 0
   f = 1.0
else
   f = oct.abs * 2
result = cutoff * (f * fkdepth)
Postby Logado » Sun Jun 14, 2015 4:24 pm
I think it works well now. But if keyfollow set to zero filter is always closed. I need to add сlassic dry/wet mix?
keyfollow.fsm
(221.72 KiB) Downloaded 906 times
Logado
Postby Nubeat7 » Sun Jun 14, 2015 6:11 pm
yes if depth is 0% , cutoff knob should set the the filter
why not do all the calculation in the pitch range
so it would be cutoff(pitch) = (pitch - reference)*depth+cutoff(pitch)
and then convert the range from pitch to 0..1
its like in the stock module just that you also subtract the reference octave from the pitch
keyfollow.fsm
(739.03 KiB) Downloaded 854 times
Postby Logado » Sun Jun 14, 2015 6:41 pm
I'm happy :D
Logado
Postby tulamide » Sun Jun 14, 2015 8:22 pm
Yes, that was a second absolute-relative error I made. Thanks Nubeat, for correcting it :)
I never saw a key follow funtion in the stock modules. So It was all from my head. Maybe that is an excuse? :oops:
Postby Logado » Sun Jun 14, 2015 9:21 pm
tulamide wrote:Yes, that was a second absolute-relative error I made. Thanks Nubeat, for correcting it :)
Do not worry, you guided me on the right path. :)
Logado
Postby Nubeat7 » Sun Jun 14, 2015 10:25 pm
don't mind tulamide, its an interesting thread, i never invested that much thoughts and your explanation makes it very clear i think its also a good thing to do it with a reference octave!
