Preview & Render modes in DAW
Postby Father » Thu Jul 02, 2015 9:39 pm
2 things i have to ask
- I don't know if this has been talked about before but, is there a way to see if the DAW is in recording mode or not?
- how can we process a signal at a lower sample rate than the original sample rate?
The goal is to have a low CPU usage while editing and previewing and full quality while recording.
Father
Re: Preview & Render modes in DAW
Postby Tronic » Thu Jul 02, 2015 10:16 pm
Tool Box
Offline Mode Primitive
Tronic
Postby Father » Thu Jul 02, 2015 11:16 pm
Tronic wrote:Tool Box
Oh yeah now i get. i thought that was for internet connection! Silly me :lol:
Say in offline mode we want our plugin to work at half sample rate. Is this possible or even relevant? I don't know anything about this subject so any information or examples are much appreciated.
Father
Postby KG_is_back » Fri Jul 03, 2015 1:05 am
Unfortunately, Flowstone can't down nor upsample its processing as a whole in a simple way. However, all code written in "hop()" code parts is "downsampled". You may put some CPU intensive parts of code in there for "realtime" version and have an non-hopped version for "offline" processing. For example filter coefficient calculation is often done this way.
Some parts of schematic may also be upsampled (search for oversampling toolkit and related articles) to for example reduce aliasing. You may have non-antialiased version of oscillators and distortion modules for "realtime" version and oversampled/antialiased for "offline" version.
Postby Father » Fri Jul 03, 2015 2:10 am
Thanks KG. That was all i wanted to know. So if you use for example hope (2) the code will be processed at half sample rate, correct? I try using hop on some code to see how it goes.
Father
Postby tulamide » Fri Jul 03, 2015 3:41 am
Father wrote:Thanks KG. That was all i wanted to know. So if you use for example hope (2) the code will be processed at half sample rate, correct? I try using hop on some code to see how it goes.
The sample rate stays the same, but only every second sample is processed (which means half of the work = less cpu load)
