binary search
binary search
Postby looji » Tue Jul 07, 2015 1:43 am
hi im a beginer :oops:
can anybody help me to convert this code (c++) to ruby(works in flowstone) ??
#include <conio.h>
#include <iostream.h>
main()
    int n;
    cout<<"array size???" ;
    cin>>n;
    cout << "_____________";
    cout<<endl;
    int a[n];
    for(int i=0;i<n;i++)
       cin>> a[i];
    cout<<endl;
        cout<<endl;
    for(int i=0;i<n;i++)        //sort
        for(int j=0;j<n-1;j++)
            if(a[j+1]>a[j])
                int temp=a[j];
                a[j]=a[j+1];
                a[j+1]=temp;
    for(int i=0;i<n;i++)        //namayesh
        cout<<a[i]<<" ";
     cout<<endl;
     cout<<endl;
    int f;
    cin>>f;
    int start=0;                 //Binary search
    int end=n-1;
    while(start<=end)
        int mid=(start+end)/2;
        if(a[mid]==f)
            cout<<"found at "<<mid;
            break;
        if(a[mid]<f)
            end=mid-1;
        else if(a[mid]>f)
            start=mid+1;
    if(start>end)
        cout<<"Not found!";
    getch();
looji
Re: binary search
Postby tulamide » Tue Jul 07, 2015 11:49 am
The question is if you gain any advantage from it. Binary search, a divide and conquer algorithm, is very stable and therefore the best choice for very large arrays. However, in pure Ruby the code gets interpreted, while the built-in search methods are compiled c-code.
binary search needs a sorted array to start with. You sort an array simply by using
myarray.sort!
For the binary search, there's a premade code block on codecodex, using recursiveness:
def binary_search(array, key, low=0, high=array.size-1)
  return -1 if low > high
  mid = (low + high) / 2
  return mid if array[mid]==key
  if array[mid] > key
    high = mid - 1
  else
    low = mid + 1
  binary_search(array, key, low, high)
If this doesn't help you, please provide a description of how you want to make use of it.
