Cant find the problem trying to fix one of my synths.
When i change the octave on a bass from -12 to 0 then to +12 and gdoing this back and down.
I have diffrent sound from the synth even if it should be the same.
Can i fix this problem some how?
Also when i change preset synth is clicking what can cause this problems?
- djbrynte
Re: Cant find the problem trying to fix one of my synths.
Hi djbrynte
Not sure about the first issue but it might be a naming problem. Every preset parameter (knob, menu selector etc.) must have a unique name.
The other issue of clicking might be solved with the simple idea below.
Preset Manager with Clear Audio function.fsm- Any use?
- (21.16 KiB) Downloaded 849 times
THere is one problem still. when chaning presets its very slow :/
- djbrynte
Thank you but i have bigger problem its lagging when changing presets :S Also even high cpu.
- djbrynte
Hi
This isn't easy to resolve without seeing your schematic unfortunately.
Your high CPU could be down to denormals: residual calculations processing very low levels of data loading the CPU.
Look at this link:
viewtopic.php?f=4&t=2808&hilit=denormal#p14872
Also, what is your PC's basic spec? Is it up to the task you have given it?
Look at this link:
