Ruby sort method on [x1,y1] [x2,y2] ... [xn,yn] data
How to take advantage of Ruby sort methods applied on simple data (actually non-hash data) consisting of a value table organized this way : [x1,y1] [x2,y2] ... [xn,yn] ?
In the application, the [x,y] table gets maintained, storing the various frequencies (Hz) and attenuation (dB) the user asked to play. Each time the user requests a new frequency/attenuation couple, such couple gets played as audio (blue schematic) by Flowstone, such table gets updated by a << [x,y] Ruby append instruction, and then, comes the difficulty I am facing : a derivative of such table needs to get generated, this time sorted by frequency (lowest frequency first). The sorting algorithm is not allowed to consume a lot of CPU%, as I don't want each frequency/attenuation change, to cause some audio glitch or DS or ASIO buffer malfunction.
I am sorry, I miserably failed in converting the [x,y] array into a hash, then sorting the hash, then converting the hash back into a [x,y] array. As consequence, I am currently relying on the following awful "hand-made" code :
Your kind help will allow people like me to quickly take advantage of the elegant built-in Ruby arrays and hash manipulating instructions. It will be funny, comparing my "by hand-made" code, with the few elegant Ruby instructions that are actually required. I am curious to discover the CPU% advantage that the native Ruby sorting instructions can bring.
# ############### generate @sortFLarray, basing on @FLarray data
# generate @tmparray, for it to contain rounded @F values along with untouched @dB values
# the rounding is required by the stupid sorting loop (NEED TO IMPROVE THIS)
@FL_len = @FLarray.length
@tmparray = []
n=0 # FLarray index
while n <= @FL_len-1
@F = (@FLarray[n][0]).round
@dB = (@FLarray[n][1])
@tmparray << [@F,@dB]
n=n+1
end # while n
@sortFLarray=[]
@sortFLarray=@tmparray # @sortFLarray now contains integer frequencies
#generate @tmparray, for it to contain data, sorted by @F
@tmparray=[]
@FL_len = @sortFLarray.length
n=0 # @sortFLarray index
val = 0
while (val <=24000) # this is a stupid load for the computer
@F = @sortFLarray[n][0]
if @F == val then
@dB = @sortFLarray[n][1]
@tmparray << [@F,@dB] # append data to @tmparray
end #if
n=n+1
end # while n
val=val+1
n=0
end # while val
@sortFLarray=[]
- steph_tsf
Re: Ruby sort method on [x1,y1] [x2,y2] ... [xn,yn] data
What you need is the Ruby Array 'sort' method. By default, this sorts an Array by comparing pairs of elements using their '<=>' operator (which returns -1 for less, 0 for equal, +1 for greater, or nil for "can't be compared"). However, 'sort' will also take a code-block which defines how to sort the items. The code block is passed each pair of items, and should return -1, 0, or +1 to indicate their order. For example:
Even more compact is the 'sort_by' method, where the block just has to say which attribute of an element should be used for comparison with '<=>':
In this case, I don't think it would make a lot of difference which you use. The 'sort' method has the advantage that you can sort things where the '<=>' comparison isn't suitable (e.g. case-insensitive string sorting using the 'casecmp' method), or sort in reverse easily by switching the comparison around.
The 'sort_by' method has the advantage that it uses a technique which only ever calls the block once for each element, so is more efficient when extracting the compared value is expensive (e.g. if it requires querying an externally stored database). However, when extracting the value is easy, it may be no better, or even less efficient than 'sort'.
Both methods also have a "bang!" version; i.e. 'sort!' and 'sort_by!'. These work very much the same, but they don't return a new Array, they swap elements around in the original Array to do the sorting. The exclamation mark is a convention in Ruby meaning "this method may have unintended side-effects" - in this case, that changing the original Array means that its previous state is lost forever and all existing references will see the new order. A lot of Ruby's Array methods follow the same pattern of "bang!" (change the original) and "non-bang" (make a new Array) versions.
It's well worth getting to know how to use these methods which take code-block, as they do result in some very compact and efficient code. For example, to do the rounding that you showed in your code takes only this:
sorted_by_freq = @FLarray.sort{|a, b| a[0] <=> b[0]}
sorted_by_gain = @FLarray.sort{|a, b| a[1] <=> b[1]}
sorted_by_freq = @FLarray.sort_by{|elem| elem[0]}
sorted_by_gain = @FLarray.sort_by{|elem| elem[1]}
# Returns an Array of [rounded_frequency, gain] elements.
rounded_freq = @FLarray.map{|elem| [elem[0].round, elem[1]]}
# Or even, using the fact that a code block can automatically split apart nested arrays...
rounded_freq = @FLarray.map{|freq, gain| [freq.round, gain]}
trogluddite, please tell how I could thank you enough
- steph_tsf
steph_tsf wrote:trogluddite, please tell how I could thank you enough
You're welcome. Just seeing that the modules and tips that I post are useful and being used to make funky new things is all the thanks I need!
