Ruby hash generate?
Ruby hash generate?
Postby adamszabo » Sun Oct 18, 2015 1:10 pm
Hi everyone!
I am wondering if it possible to create a hash for an input string with Ruby? I am especially interested in the short ones like adler32, crc32 or joaat. I wrote in the word "Hello" and it gave me a lot of different hash types:
adler32: 062c0215
crc32: 3d653119
joaat: c8fd181b
Here are the results: https://md5hashing.net/hash/joaat/c8fd181b
I have been searching for some help online and all the ruby codes seem to use some Zlib, which I dont even have a clue what that is. Does any one have any expertise in this field? :)
adamszabo
Re: Ruby hash generate?
Postby tulamide » Sun Oct 18, 2015 3:16 pm
As much as I would love to help, Ruby forbid it. I had a look at the original code for Jenkins one-at-a-time (Joaat). The code is quite simple and it wasn't very difficult to convert it to Ruby.
However, the original code takes advantage of overflow. Here's an example. Say, I have a 4 bit number
a = 0b0001 # 1 as bitsequence
a = a << 3 # all bits shifted to the right 3 times = 0b1000 or 8
## Now what happens if we shift 4 times?
a = a << 4 # all bits shifted to the right 4 times = 0b10000 or 16
In C++ this wouldn't be possible, because the number is defined as 4 bits. The 5th bit overflowed. It is just truncated and the result would be
a = a << 4 # all bits shifted to the right 4 times and truncated = 0b0000 or 0
The Joaat code uses this behaviour to its advantage several times. Unfortunately, Ruby only knows to types of integer numbers, fixnum and bignum. Fixnum is based on the system (32 or 64 bits). As soon as the number exceeds the allowed number of bits it is automatically converted to a bignum, which is basically endless.
I don't know how to prevent that. But, since I have hope that Myco will have a cool idea, here's the code tranlated 1:1, meaning it isn't working yet:
#uint32_t jenkins_one_at_a_time_hash(char *key, size_t len)
#    uint32_t hash, i;
#    for(hash = i = 0; i < len; ++i)
#        hash += key[i];
#        hash += (hash << 10);
#        hash ^= (hash >> 6);
#    hash += (hash << 3);
#    hash ^= (hash >> 11);
#    hash += (hash << 15);
#    return hash;
def joaat(key)
   hash = 0
   key.each_byte do |c|
      hash += c
      hash = hash ^ (hash >> 6)
   hash += (hash << 3)
   hash = hash ^ (hash >> 11)
   return hash
joaat("hello").to_s(16)
I hope the 32bit truncation will be possible somehow and the sign bit used as number bit. Then it will work. Come on, you programmers :)
Postby KG_is_back » Sun Oct 18, 2015 5:36 pm
You may possibly use logical bitwise AND.
def overflow(n,bitdeapth)
n & (2**bitdeapth -1)
It will output an unsigned integer only... I might have to think more deeply about it to make it work with signed...
Postby tulamide » Sun Oct 18, 2015 8:21 pm
Yes, please think it over, maybe you'll have an idea.
I also thought about bitmasking. The thing is, it just works one way (for shifting <<). Again a 4bit example:
a = 0b1001 # number 9
a = a >> 2 # a will be 0b001001 or 9
a = a & 15 # bitmasking  over 4 bit length, a will still be 0b1001
In C++ a would be 0b0010 = 2 instead
Postby KG_is_back » Sun Oct 18, 2015 9:34 pm
I think you are wrong about the bitmasking (at least my experimentation confirms your're wrong). ">>" actually denotes LOGICAL right bitshift. That means digits are shifted right, the ones missing on the left get zero and the ones that "overflow" on the right are forever lost.
a=0b1001 =9
a= a >> 2 #gives 0b10 = 2
a = a << 2 #gives 0b1000 = 8
also I think I have a solution to the problem:
def overflow(n,bitsize)
n=n & (2**bitsize - 1)
n= (n>= 2**(bitsize-1)) ? n-(2**(bitsize)) : n
this little method will give you overflow result represented as a SIGNED integer. to get an unsigned result, just comment the last line...
Postby tulamide » Sun Oct 18, 2015 11:04 pm
Now that is cool!
I admit, I didn't test what I thought would happen, so thanks a lot for taking the time to test Ruby. Now I'll integrate the overflow method (probably tomorrow, to late tonight). I'm afraid it needs to be called after each shift, but speed hopefully is not of interest, at least not for a first working version.
Postby tulamide » Mon Oct 19, 2015 2:22 pm
Simple Joaat Hash Generator
Whenever the string input is changed a hash is generated.
Many thanks to KG for his bitmasking idea. It turned out that unsigned works correctly.
JOAAT.fsm
(763 Bytes) Downloaded 840 times
Postby adamszabo » Mon Oct 19, 2015 2:47 pm
Very cool guys! Im still trying to understand how it works :) Can this code do a reverse as well? So I write the hash and outputs the original string?
adamszabo
Postby KG_is_back » Mon Oct 19, 2015 6:20 pm
adamszabo wrote:Very cool guys! Im still trying to understand how it works :) Can this code do a reverse as well? So I write the hash and outputs the original string?
I believe that is not possible. The whole idea of hashing is, that from a big string (or a file) you generate small short hash (a text or a number). The hash is however usually not unique (there may and most likely are strings with the same hash), though it is very hard to find two different strings with the same hash. They are mainly used to verify if given file is original (if the file was modified, it will generate different hash). The process is not reversible - the hash generation is a destructive process.
Postby tulamide » Mon Oct 19, 2015 6:50 pm
What KG said. If you followed this thread you might have noticed that I talked of truncating. At least then it will not be reversible, since information is lost. I don't know if there are hash algorithms that are non-destructive, but Joaat is destructive for sure. If you see some kind of de-hashing somewhere it is most probably a huge library of known source/hash relationships that are just looked up.
