2's Compliment in Ruby
Postby aronb » Tue Nov 03, 2015 4:04 am
How do you do 2's Compliment conversion in Ruby ?
I have a 16bit 2's compliment number that needs to be signed integer -32768 to 32767
thanks for any input...
Aron
aronb
Re: 2's Compliment in Ruby
Postby KG_is_back » Tue Nov 03, 2015 11:39 am
Numbers in ruby are 2's compliment. If I assume correctly, your 16bit signed number is being displayed in unsigned format? If that is correct, simply subtract 2^16 in number is above or equal 2^15
def unsigned_to_signed(x,bitdeapth)
if x>2**(bitdeapth-1)
x-2**bitdeapth
else
x
Postby aronb » Fri Nov 06, 2015 7:18 pm
Thank You KG_is_back ! ! !
I initially did the > test incorrectly... DOH
Works perfectly now :D
Have a great weekend,
Aron
aronb
