Help with selector
Help with selector
Hello gang,
Talk about not being able to figure out simple stuff. I need a button that will increment a selector to N (any number) and when it reaches the last number will go back to the start (0 or 1). I have tried several configurations but just can not get it to work right. I have been trying to get this to work for 3 days now. Feel pretty dumb right now! Can anyone help, PLEASE, with a working fsm. Many thanks in advance.
Later then, BobF....
- BobF
Re: Help with selector
A year ago I posted a "loop repeater" ( click me to be directed to the thread, where you can also learn about the advanced counter ), which does the job just fine
It's a solution in green, I hope you don't mind?
Infinite_stepper.fsm- (564 Bytes) Downloaded 758 times
In RUBY or using primitives ?
Thanks tulamide. I will check this out soon.
Rjhollins, in primites first , then if that does not work, I could try Ruby.
Thanks much.....
Hey tulamide, many THANKS! It worked perfectly. Thanks again.....
Thanks much.....
- BobF
