How can I make persistent ruby data within plugin?
I create an array and I randomize its value using a ruby function:
Once I create it, I'd like that every time I edit ruby script (recompile) or I close/reopen the project/plugin, the array stay persistent. So I work on the same values every time.
Once I re-random it, it recreate the array and store the new one. How this is possible in ruby? In Kontakt scripting for example I use make_persistent(myArray).
Is there somethings similar in FlowStone?
Thanks!
def init
@lfo_size = 100
@lfo_shape_1 = Array.new @lfo_size
def event i, v
if (i == "start")
# somethings
elsif (i == "random")
randomLFOs
def randomLFOs
for i in 0..@lfo_size
@lfo_shape_1[i]=rand(100)
Thanks!
- Nowhk
Re: How can I make persistent ruby data within plugin?
You can use saveState and loadState methods to store values. it is described in the manual. However, I'm not sure if it will do what you are looking for
KG_is_back wrote:You can use saveState and loadState methods to store values. it is described in the manual. However, I'm not sure if it will do what you are looking for
Uhm yeah, it seems to works pretty nice:
def loadState v
@lfo_shape_1, @lfo_shape_2 = v
def saveState
[@lfo_shape_1, @lfo_shape_2]
Why it shouldn't works? Thank you!
- Nowhk
