add tab before each string
Postby GLIC » Wed Mar 11, 2020 8:31 am
Hello.
Here I am stuck again. How can I add tab before each line string?
Example:
data1
data2
data3
becomes:
tab data1
tab data1
tab data1
Thank you
GLIC
Re: add tab before each string
Postby kortezzzz » Wed Mar 11, 2020 10:47 am
It has been discussed yesterday. Use the Ruby editor (1 string array input, 1 string array output) and add this code:
output @ins[0].map { |item| "tab " << item }
Then every array index gonna get the "tab" prefix.
kortezzzz
Postby GLIC » Wed Mar 11, 2020 11:21 am
Thank you, but it does not work.
It`s easy for programmer to say use Ruby. Using such horrible and difficult to learn language as Ruby defeats point of using FLowStone. Not everyone has same type of thinking and can do typical coding. For people like me visual programming is almost only way we can build something. Plus I just do not see a decent way to learn Ruby in FlowStone environment, because syntax does not match fully.
Is there any websites for learning this effectively?
GLIC
Postby GLIC » Wed Mar 11, 2020 11:27 am
undefined method `map' for "":String
GLIC
Postby kortezzzz » Wed Mar 11, 2020 3:28 pm
Believe it or not, in coding, I'm worse then you by any mean, but this piece of code posted yesterday by our forum member tulamide and it works as is by just coy\pasting. But attached an example schematic for downloading just to make sure you got it.
(ADD STRING TO STRING ARRAY INDEXES).fsm
Made with 3.0.6 version
(350 Bytes) Downloaded 870 times
kortezzzz
