Renaming a file on C:\ with a switch knob
Postby Mr. Mac Snoer » Fri Dec 04, 2015 7:26 pm
Lets say I have a file "a.txt" on my c:\.
When I turn the switch to "true" in the gui I want to rename "C:\a.txt" to "c:\xyz_a.txt".
When I turn the switch to "false" in the gui I want to rename the file back to "c:\a.txt".
Any hints would be appreciated. :)
Mr. Mac Snoer
Re: Renaming a file on C:\ with a switch knob
Postby Mr. Mac Snoer » Mon Dec 07, 2015 9:53 am
File.rename("old_name", "new_name")
should work... :)
..now I just need to connect this to a switch
Mr. Mac Snoer
Postby Mr. Mac Snoer » Thu Dec 10, 2015 5:42 pm
Here is another simple solution with Ruby Shoes.
The folder is C:\Test\, the file is called A.txt and will be renamed to INACTIVE_A.txt with button one and back to A.txt with button two.
Shoes.app do
  stack do
    button "Rename A.txt to INACTIVE_A.txt" do
      Dir.chdir("C:/Test")
      File.rename("A.txt", "INACTIVE_A.txt")
    button "Rename INACTIVE_A.txt to A.txt" do
      File.rename("INACTIVE_A.txt", "A.txt")
I will try with Flowstone. :)
Mr. Mac Snoer
Users browsing this forum: No registered users and 44 guests
