OWI Robotic Arm Edge
Postby bradnorwood » Thu Dec 15, 2011 7:04 pm
Does anyone know how to get this arm to work with Flowstone? I have OWI's technician contact info if anyone is interested or has tried? Brad
bradnorwood
Re: OWI Robotic Arm Edge
Postby NullARC » Mon Dec 19, 2011 3:15 am
Do you know if the arm uses servos or standard motors?
I believe that if you connected the leads to a servo/motor (whichever the arm uses) controller, you
should be able to make up a Flowstone program that can control it.
If you look in the "Flowstone Examples" section there are Flowstone programs for many different
controllers to get you started communicating between your computer and whatever controller you choose and the arm.
Hope this gets you started in the right direction! :)
NullARC
Postby bradnorwood » Mon Dec 19, 2011 5:40 pm
it uses regular motors, it already has a board that goes to usb and I have software for it, I want to make custom software though
bradnorwood
