Need a Ruby float array solution
I'm trying to find a simple ruby solution that would replace the whole array values to my own value. For instance, if the array is:
0.5
0.7
0.6
0.4
I would like to replace the whole bunch of values with 0.1 to end up with:
0.1
0.1
0.1
0.1
Why is it needed? because while FS's multisample module extracts the sfz file's values correctly, it yet doesn't allow determining them with knobs, so I can't prevent fundamentals values like "release=29" to be streamed... moreover, for instance, if I would like to customize the each of the AHDSR array values with my one desired values (with knobs), I have no way to control the arrays correctly. Any suggestions?
0.5
0.7
0.6
0.4
0.1
0.1
0.1
0.1
kortezzzz - Posts: 763
Re: Need a Ruby float array solution
I can only answer the Ruby part. There's a method for arrays, called fill. It takes an object as parameter.
If you create a float array input and a float input, and name them "array_in" and "float_in", plus a float array output, then this code should work:
This will activate whenever you change the float array at input or the float you wish the array to fill with.
ary = 0.5, 0.7, 0.6, 0.4
ary.fill(0.1)
# Now the array is [0.1, 0.1, 0.1, 0.1]
def event i, v
a = @array_in
a.fill(@float_in)
output a
Thanks tulamide, works perfectly and now, each aspect of the multisample module can be controlled manually
