How do u refresh preset manager from buggs?
• Page 1 of 3 • 1, 2, 3
Is this program not working or im doing something wrong. Im using FL studio. Im cloning layers and deleteing to test.
Everytime it crash.
Have a i wasted my time on this?
Some one talked about preset manager bugg before. That everything need to be ruby to get working.
If u gona use a poly portamento in FL synthmaker. u need to use over 3:06 or above or something. And if u use that version u now have the preset manager bugg.
Why is the synths working ine on FL studio 64 bit? But when they work there u have the blurry design bugg?
Flowstone.com better?
Seriously? can some one help me into this if its realy worth doing synths or is this buggs permanent?
Also everytime u delete a layer in FL studio. U have the repeat sound bugg. Like repeating tool.
Also was this program not made form FL studio? why cant they support it so its working?
Check this for example.
viewtopic.php?f=3&t=2902
Everytime it crash.
- djbrynte
Re: How do u refresh preset manager from buggs?
This program is not for kids, its a complicated one, if there are buggggsss its your fault not the programs.
- adamszabo
adamszabo wrote:This program is not for kids, its a complicated one, if there are buggggsss its your fault not the programs.
Wow you should work for the marketing department,
Isn't this the Microsoft business plan every update fixes one bug and creates two (or why would you buy the update)
cynical? I have been called that, but not always for long
It all depends what you want DJ B, sounds like your looking for the holy grail and much like that, its always in view shining on the horizon but will be forever out of reach.
You really need to decide what you want from the software, personally as a musician I still use SM I've used it for years, can whip projects together fast (know my tool box inside out) and is bug free.
Where as if you want to sell your projects commercially learn c+, until there is x64 and multi platform FS is always going to be seen as at the best SE's poor dumb cousin. Hell it seems like SM's poor cousin, take a look sonically what was produced with SM, anything new?
- Xtinct
Xtinct i just doing 1 single synth. I also reduced alot to take it down. But still its impossible to make a synth it seem.
Do u not have the bugg? I dont understand why it hapens. Do you know why it hapnens? Mybe u can explain if u know.
But u must understand when after all this years it seem u cant od aa single synth without buggs. Or im doing anything wrong?
Adam then go play some where else
Xtinct mybe you just make effects and dont care about the synths who knows? haha!
Adam btw this will affect your synths to if its permanent bugg.
Btw mybe its better to help then trying to fool with some one?
- djbrynte
You must understand that throwing a big tantrum like a child doesnt get you anywhere around here. You always make topic with a vague description and then you are surprised no one replies. If there is a problem its 99% your fault and 1% the programs. There are always workarounds and you can get help from here but you should do that in a proper manner. Record a video of your problem, or strip down the buggy part of your project and post it so we can have a look. Btw, none of these problems happen in my synth. I dont get 40% cpu with unison, I dong get repeating sounds and I dont get crashes which you have mentioned in your 100 other separate posts.
So the bottom line is, if you want the best success rate of getting help always describe your problem as best you can and provide a project otherwise we will be in the dark.
- adamszabo
Ur right it must be something im doing wrong in my synths.
Its strange because ur synths is working i guess?
My nerves goes up and down :S 2 days of work. no success. I did try delete half synth and more even if nots big and still this crash.
Im on 3.05. i tested all versions up to beta 3.09 and it still crashes.
1, "Baztard" crashed while processing. disabled.
2, Freezing some times and sound stopping.
3, I add 1 synth layer of baztard. Then adding a midi file to the baztard synth. Then im adding another layer of baztard. i mean clone the baztard so i have 2 of them.
Then while baztard is playing on 1 of them. i try delete the second one. Then it freeze again. And sound repeating like. bip bip bip. ||||||. like inzane repeat. and then program crash.
It has to do with layers and deleteing 1 of them make it crash.
- djbrynte
You really need to make a video of this and upload it to youtube because I get no crashes here, I clone I delete I do everything and it works fine.
- adamszabo
Will make me the bad guy, but:
Adam has a point here. It isn't helping to flood the forum with strange posts. Djb is doing it so often that I don't even bother to read any of them. It isn't very difficult to create a reasonable topic. Describing the issue in detail, providing fsm, screenshots or videos if they add something to the description and a certain form of kindness will result in more and better help.
Personally, I get in disgust when reading things like "Buggstone.com", or questions that nobody can answer, like "Have a i wasted my time on this?" It doesn't motivate me helping.
Also lets keep in mind that FlowStone is also an application developed by Malc and now that Myco is helping too, its childish to bash the program if something doesnt work. Calling the application buggstone.com is an insult and not fair for the developers. We are all trying to help here, but we wont be able to magically fix something thats not explained properly.
- adamszabo
1. Explain to me what is normal post for you?
2. What is your skillz compare to others?
3. Do u like help people thats good and then people that dont undrstand everythign because of dyslexia and other problems? then u bullying? If u read the post here all whats going on here is trying take me down.
http://www.stopcyberbullying.org/contact_us.html
i have had problem with bullying when i grove up. Now i understand why. people dont think of helpeing people. They just wana put them down.
I asked about buggs and stuff before. What did u do? or people. yes same thing. Why dod u asking me to make normal post. When im trying to ask here. Why do you think i ask many questions? When i get cyberbullying.
Also why do people act like this. Its realy low.
Why do you think u get upset when working on 1 bugg nonstop for 2 days? Nothing helps. Why do you not thinkg it can be the program then? How much have u spend on buy stuff for this program and the result become a bugg ?
But what ur doing now is
http://www.stopcyberbullying.org/contact_us.html.
What i learn so far people dont care of others. Just respect is the thing. If u can have respect then ur ok in ur eyes prob?
Do you know there is people with diagnosis. Also why shall i spend time expain something to you when i get a finger when asking for help.
What inside this topic has been help?
What is your goal in this topic? Let me know explai nwhy u come here and telling me this? Have u ever have in mind mybe helping me instead of blaming me for stuff?
Btw i hope your lucky crushing some one down. Always when asking get the finger. Why do u think i make such post mybe hard getting help of you people. I gort same replis before some where when i made a post. Its not fun posting in this forum. But ur goal is to take me out i know. It feels so. Why not help a guy who have hard? instead of put him out?
- djbrynte
