"Redrawing GUI" Open pages
Postby Wassaka » Fri Jan 01, 2016 10:22 pm
Hi! I am Wassaka and I am newbie in FlowStone. I want to put sections in my synth, like effects, osc, filter... etc, but I want to put them in the same place, and choose with Radio-buttons, the section. I tryed to do this but it doesn't work... Please, can you help me? Or pass me the schematic. Thanks and Happy New Year!!! :mrgreen: :mrgreen:
Wassaka
Re: "Redrawing GUI" Open pages
Postby kortezzzz » Sat Jan 02, 2016 12:49 am
Hi and welcome.
Here is a very basic example using the radio buttons method. Hope it help.
( Basic filter rack example).fsm
(215 KiB) Downloaded 891 times
kortezzzz
Postby RJHollins » Sat Jan 02, 2016 1:09 am
Thanks for posting this example. Interesting all the different ways this idea can be realized.
One issue :o
When I first loaded in the example schematic, got a RUBY error. Located in the 'radio buttons bill v concept' module.
To correct, I just had to turn OFF then ON the RUBY box ... but the question ... why the error? how to solve ?
'NoMethodError ... in method DRAW ... undefined method {} for nil:NilClass"
Postby Wassaka » Sat Jan 02, 2016 2:11 am
kortezzzz wrote:Hi and welcome.
Woow man, thanks you very much!!
Wassaka
Postby billv » Sat Jan 02, 2016 4:48 am
RJHollins wrote:why the error? how to solve ?
Notice RJ there are two arrays in the draw section that I didn't initialize properly.
Drop this into draw section
@points = 2 if @points == nil
@val = 0 if @val == nil
Will update those radio selectors one day.....
billv
Postby RJHollins » Sat Jan 02, 2016 5:08 am
Ah ... Thanks Billv ...
That fixed it.
.... and THANKS for sharing experience and examples to the FS community.
8-)
Postby kortezzzz » Sat Jan 02, 2016 8:32 am
Oh, sorry, forgot to add "after load" and "after duplicate" modules into it's matching module. That's should work without billv's current fix as well. Uploaded the schematic.
@billv
I would like to try your fix but probably couldn't locate the "draw section", since I'm getting first start errors without
the "after" modules added. Can you please say on what line should we add your fix?
( Basic filter rack example)fix.fsm
(215.02 KiB) Downloaded 822 times
kortezzzz
Postby billv » Sat Jan 02, 2016 10:47 am
kortezzzz wrote:forgot to add "after load" and "after duplicate
Yeh...i just noticed they were missing from the selector you posted first.
Definatly leave those in.
The "draw section" i refer to is the section of code that begins
def draw v
'put code in here'
billv
