Problem with knob
Problem with knob
Postby SampleScience » Tue Feb 23, 2016 3:12 pm
When I try to load my own knob, even if I set the right pixel size the knob doesn't work; it just goes around in all directions. Also, I don't see all the options I should see when I watch tutorials on YouTube, I just have a limited set of options in my Animeted Knob module. Any idea why? I've uploaded my file so you can check it out.
crazyknob.fsm
(23.68 KiB) Downloaded 807 times
SampleScience
Re: Problem with knob
Postby adamszabo » Tue Feb 23, 2016 3:28 pm
Your sweep angles are wrong, in the knob ruby code change it to this:
@startAngle = 0
@sweepAngle = 360
adamszabo
Postby SampleScience » Tue Feb 23, 2016 5:06 pm
adamszabo wrote:Your sweep angles are wrong, in the knob ruby code change it to this:
@startAngle = 0
@sweepAngle = 360
Thanks! It worked! :D
SampleScience
