Download does not unpack
Postby TheAudiophileDutchman » Fri Jul 16, 2010 10:45 am
The free download of FlowStone seems to be corrupted!
T A D - since 2005
Re: Download does not unpack
Postby admin » Fri Jul 16, 2010 6:11 pm
admin
Site Admin
Postby dieram » Mon Jun 20, 2011 5:10 pm
I am also having troubles downloading FlowStone FREE. After about 10M it says that the download has been interrupted. Also tried with the link that you gave below. Please advise, thanks.
dieram
Postby DSP » Tue Jun 21, 2011 11:58 am
Just tested it from here and it works fine. So it must be something at your end?
A few things to check:
a) have you enough disk space on C: (even if you save it else where it always downloads to C first then transfers it over)
b) Is your virus checker blocking it?
c) Do you have administrator rights? Sometimes this can block downloads.
d) Is your internet connection ok, is your wifi dropping out?
Support: you could always email support, they are very helpful and may send you the file?
info@dsprobotics.com
DSP
