Manual & Prims Typo & Errors
Postby Nowhk » Wed Mar 02, 2016 6:55 pm
Maybe would be nice to stick this Topic on the Forum, and let the users put suggestions where the manual is wrong and/or incomplete.
I'll start with this:
Page 99, Area GUI Component. "an are defined by coordinates of top-left corner, a width and a height"
Page 132, Readraw Area module. The two pictures are the same. I guess one should be the implementation of the Redraw Area module (which I can't see). Can you fix it?
About this last point: how would the Redraw Area Module be? I'm trying to improve some drawing, and this might be the right starting.
Nowhk
Re: Manual & Prims Typo & Errors
Postby Nowhk » Wed Mar 09, 2016 4:29 pm
New typo. Hover the Trigger Blocker prim: "Prevents a change in vaue from...".
Nowhk
Postby Spogg » Wed Mar 09, 2016 6:51 pm
The images in the manual on p512 and 514 don't match the toolbox prims.
The actual toolbox prims are labelled as just Array and Param which makes finding them tricky based on the manual description and images.
I suspect the labels on the prims themselves is wrong.
Postby Nowhk » Thu Mar 10, 2016 4:53 pm
Float Array prim. "Trigger when finished changing the array" notation has an empty space before it, which de-align the texts.
Nowhk
