Where is the most appropriate place to request a FS VST plug
Hi all,
I have need of a VST utility plugin. I know exactly what I want, I just need to find someone that will/can build it in FS and export it as a VST. One of these days I'm planning on learning FS, but I need this plugin now, and I figure someone out there could use a few extra buck to whip it up for me in the mean time.
Can I post the request to this forum?
- DruMunkey
Re: Where is the most appropriate place to request a FS VST
Of course you can. Just use this 'General' subforum.
But don't expect much interest. Building a VST is hard work. I doubt you will be able to pay a reasonable sum to cover the workhours. Also, the development of a plugin is a long process, so if you need it now, you should have asked a year or two ago.
Nevertheless: Good luck.
(EDIT: Don't pm me, I'm not up for it)
