Mouse Scroll commands
Postby Rocko » Tue Mar 15, 2016 12:25 pm
Is there any way for me to control 'mouse scroll' button via flowstone (Ruby? Green?) ?
Thanks,
Rocko
Rocko
Re: Mouse Scroll commands
Postby adamszabo » Tue Mar 15, 2016 8:55 pm
Yes you can do it in the 3.0.9 beta
adamszabo
Postby Rocko » Wed Mar 16, 2016 1:11 pm
For 3.0.9 Beta2 I see a 'mouse wheel' module in green. Is that what you are referring to or is there a way to implement it in a RUBY code?
Thanks,
Rocko
Rocko
Postby Tronic » Wed Mar 16, 2016 1:15 pm
Ruby using:
def mouseWheel x,y,w
    # do something with x,y,w
Tronic
Postby Rocko » Sun Mar 27, 2016 10:25 am
This doesn't seem to work correctly. I'm simply trying to output the x,y,w readings to float (see simple schematic) and I receive wrong data.
Sometimes the 'w' data get updated (1 or -1) and sometimes it doesn't.
Am I doing something wrong or is there still a bug with 3.0.9 BETA ?
def isInMousePoint x,y
   true
   output 0,x
   output 1,y
   output 2,w
mouseWheel_test.fsm
(1.01 KiB) Downloaded 1047 times
Rocko
Postby Rocko » Wed Nov 30, 2016 4:08 pm
Has anyone succeeded to work this out ?
Rocko
Postby aronb » Wed Nov 30, 2016 7:06 pm
Hi Rocko,
Yes... ;)
You can find an example here...
http://www.dsprobotics.com/support/viewtopic.php?f=3&t=3860&start=0&hilit=mouse+wheel
I then used your example and got it working (3.0.9 Beta 2)
mouseWheel_test_AB.fsm
Mouse Wheel Ruby
(1.06 KiB) Downloaded 979 times
Aron
aronb
Postby Rocko » Thu Dec 01, 2016 8:05 am
Thanks.
So this function will not be functional with v3.08.1, correct?
Rocko
