Primitive EdOPEN not working as expected
Postby RJHollins » Thu Mar 24, 2016 4:17 am
OK ... snag.
I was testing the use of the prim EdOPEN, which I understand triggers a Boolean value TRUE when a VST plugin GUI is opened. [something like that] :|
The issue ... with REAPER ... all FS plugins load in as 'bridged' ... fine.
The problem ... if the FS VST is loaded in and displays [automatically] because it is bridged, the EdOPEN does not go TRUE.
If the VST GUI is closed, and THEN re-opened ... EdOPEN goes TRUE ... everybody happy.
I need 'happy' when the VST first loads and is displayed.
help.
Re: Primitive EdOPEN not working as expected
Postby Nubeat7 » Thu Mar 24, 2016 9:31 am
hmm, it works here ( v4.76), but there are some things to point out,
per default reaper deactivates the audio device when it is inactive, so also selectors (i think only ruby) do not work as expected (after clicking on the selector you need to click outside the vst window to get the action done)
to avoid this go to preferences in reaper -> audio -> and turn off "close audiodevices when application is stopped or inactive"
then everything should work as expected..
hope this helps!
Postby RJHollins » Thu Mar 24, 2016 10:43 am
Hi NuBeat,
Yes ... I've had that disabled for some time ... probably you helped me identify that issue back then.
This is something different ...
I have a TIMER [countdown] that starts after a defined period of time. I currently use AFTERLOAD to trigger the timer, but wanted to try EdOPEN as that seemed an option that might be even better.
It ain't working unless I first close the VST, then re-open ... then works.
Postby Nubeat7 » Thu Mar 24, 2016 10:38 pm
just tried it with this little test vst and the ticker starts at first loading.
FS 2.06 / reaper 4.76 64bit
edopentest.fsm
(1.4 KiB) Downloaded 959 times
Postby tulamide » Thu Mar 24, 2016 11:09 pm
Nubeat7 wrote:just tried it with this little test vst and the ticker starts at first loading.
I can confirm this for FS 3.0.6 / Reaper 5.1.1 32 bit
Postby RJHollins » Fri Mar 25, 2016 2:46 am
wait a minute ...
WHY do you have an 'AFTERLoad' prim connected with the EdOpen prim ???
I was using the EdOpen only to provide the trigger to start the clock. If I put BOTH, won't the clock routine start because of the afterload trigger ?
I should add ... I'm not using the same type of a timer/clock as in your RUBY module. I'd have to completely redo that for my project ...
but to the first question ?!?
Postby Nubeat7 » Fri Mar 25, 2016 9:33 am
RJHollins wrote:WHY do you have an 'AFTERLoad' prim connected with the EdOpen prim ???
i just left it there, its the stock ruby ticker, i just exchanged the manual on / off boolean with the edopen prim...
you can try it without... and see if there is a difference.
the ticker itself is just an example, should be no problem with any custom ticker or counter or what ever you want to activate, the question is if the boolean state is forward triggered after loading the plugin...
Postby RJHollins » Fri Mar 25, 2016 9:52 am
aahhh ... after seeing your example, that's what made me wonder.
ok ... to test this, I think I should be able to just display a BOOLEAN and use one of the graphical trigger indicators to see if I get a pulse.
THANKS for peeking in. Your insight is always appreciated.
8-)
Postby RJHollins » Sat Mar 26, 2016 9:36 am
snag #2 :roll:
Inside this RUBY timer I'm getting NoMethodError: underfined method - scheduleMethod
using FS v3.04
is there a fix or another way ?
Postby Nubeat7 » Sat Mar 26, 2016 1:50 pm
oh, you should have a stock ruby ticker with the old methode in your toolbox, just use this one instead...
