Oversampling
Oversampling
I try to use oversampled hard clip with oversampling kit..
x2 much clearer but no difference between x2 and x4. what im did wrong?
Oversampling test.fsm- (795.76 KiB) Downloaded 855 times
- Logado
Re: Oversampling
Use the Up/Downsampling modules from the "Oversampling Kit (MyCo)" Module. This kit has many fixes and optimizations that the original kit didn't have.
MyCo - Posts: 718
Re: Oversampling
Thank you, MyCo
a few noob questions.
the name of this method? i want read some teory how this work
this method adds a latency?
- Logado
Re: Oversampling
Don't know the exact name. But it's just oversampling using half band filters. It doubles the sample rate removes the aliasing using a half band filter then it goes into your effect and finally it uses the half band filter to limit the frequencies to 1/2 of niquist frequency and outputs every second sample interpolated.
It just looks a bit stupid in FS, because we can't process samples in higher samplerates. So we process even and odd samples of the higher samplerate stream in 2 separate streams (running at original sample rate in parallel)
MyCo - Posts: 718
