complex numbers in ruby
Postby tester » Thu Jun 02, 2016 9:38 pm
input = array
In ruby:
1.
How to convert array into array of complex numbers? (is this handled as one "object"?) I mean - from what I see, ruby is handling complex numbers as single objects, but I don't know to what degree.
2.
How to multiply (and other operations) array of complex numbers through a number and through another array of complex numbers? (items with the same indexes, so resulting array has the same size)) I mean - is it working the same wah as with real numbers?
3.
How to split the number / array of complex numbers into real part on out1 and img part on out2?
Re: complex numbers in ruby
Postby tulamide » Thu Jun 02, 2016 10:07 pm
All methods and behaviour of complex numbers explained in detail here:
http://ruby-doc.org/core-1.9.3/Complex.html
Postby Tronic » Thu Jun 02, 2016 10:28 pm
tester wrote:input = array
In ruby:
1.
real = [0.5,2.5,3.8]
imag = [10.5,20.5,30.8]
cplx = Array.new real.size
cplx.each_index {|idx| cplx[idx] = Complex(real[idx],imag[idx]) }
2.
... normal ruby iterator
3.
real = cplx.collect{|i| i.real}
imag = cplx.collect{|i| i.imag}
Tronic
Postby tester » Fri Jun 03, 2016 8:32 pm
Thanks Tronic!
