2.01 Crashes on load
Postby billv » Tue Feb 07, 2012 10:20 pm
Can't open program. Crashes on load
Visual Studio "Just in Time De-bugger" pops up with:
An unhandled win32 exception occured in Flowstone. exe (1032)
billv
Re: 2.01 Crashes on load
Postby DSP » Tue Feb 07, 2012 11:20 pm
Works fine here?
Can you give us a little more information? OS etc.
DSP
Postby Embedded » Tue Feb 07, 2012 11:21 pm
Works here too?
Embedded
Postby Cat5 » Tue Feb 07, 2012 11:30 pm
Everything ok here: Win 7 64 Bit
Cat5
Postby Embedded » Wed Feb 08, 2012 1:07 am
Sounds like something is screwed up on your PC, here are some things to try:
A. Check there are no files lurking in the recovery folder:
1. Click the Windows Start button, type Run in the search box and press return
2. The Run window should appear. Type AppData and click OK.
3. In the resulting explorer window navigate to Roaming\FlowStone\Recovery
4. Move or delete all files from in there.
B. Could be something incorrect in the registry:
1. Click the Windows Start button, type RegEdit in the search box and press return (click Yes on the security dialog)
2. Navigate to HKEY_CURRENT_USER\Software\DSPRobotics\FlowStone
3. In the list to the right find "Window Position"
4. Right-click on the Window Position key and select Delete
5. Now close regedit and run FS again
If this fails it might be worth repeating the above but this time delete the FlowStone key.
Embedded
Postby billv » Wed Feb 08, 2012 8:18 am
Thanks for all the feedback.
Did step A and step B. No good.
Did not find any "Flowstone Key" file.
Uninstalled Flowstone. Deleted all registry and appdata files.
Re-installed.No good.
Step A and step B again. No good.
Un-installed Visual basic.
Restart CPU.
Flowstone opens but the (Just in time Debugger) still there but now can be minimized.
Looks like the problems at my end, except for that "Flowstone key" thing I can't find.
billv
Postby Embedded » Wed Feb 08, 2012 12:39 pm
If the registry keys aren't there then it could be that you don't have administrator rights?
The keys are created on install, but you need permissions.
Embedded
Postby dmccommon » Wed Feb 08, 2012 8:02 pm
I am having a similar problem .. It loads once then crashes then won't re-open .. Win 7 Pro x64 .
If I uninstall then reinstall then it will open once then crash then won't reopen>?
2.0.0 would crash occasionally but would reopen ..
DMc
dmccommon
Postby billv » Wed Feb 08, 2012 9:46 pm
I am the CPU Administrator.
Also note: In "Add or Remove Programs"(Control Panel) it's listed as Flowstone 1.0 ??????????
billv
