green divide float array by a float missing
Hey everyone,
I have never needed this in green and for the first time I looked for it, I noticed I didn't have it. I have all the others for float arrays, but missing this one. I am using 3.0.6 pebble. Has anyone experienced this?
BTW I did the obvious by turning off the filters etc. If someone can attach an .fsm with that green in it? It would solve my problem
Thanks
Thanks
pshannon - Posts: 144
Re: green divide float array by a float missing
Can't you just use the generic 'blank input' green divide to divide any green you want?
k brown wrote:Can't you just use the generic 'blank input' green divide to divide any green you want?
No because it turns the whole thing into an array. I want to divide the whole array by a single value for scaling values. Does this mean it is not included??
Did you try it? I've used that to divide float arrays (to attenuate them) using a float input to the Array divide - works fine.
But no, I don't have a Float Array Divide specifically.
Invert the Array Multiply.
You can use a float divide, or the invert prim.
Array Divide.fsm- Made with 3.0.8
- (406 Bytes) Downloaded 987 times
- ChrisHooker
Thanks Chris that worked.
k brown: "Did you try it?", no I did not because I just assumed that green was supposed to be there.
Thanks again!!
Thanks again!!
