How to read midi input signals from usb attached keyboard
Postby bellscotcv » Sat Mar 03, 2012 4:23 pm
Can anyone give me the steps for how I would read midi input signals from a USB attached midi keyboard AND/OR midi output from common audio recording software if it is running local to same PC that flowstone is installed on?
Thanks in advance.
-Scott
bellscotcv
Re: How to read midi input signals from usb attached keyboar
Postby AnthonyTower » Sun Mar 04, 2012 1:20 am
First start with a MIDI In component or an empty module where you have added a MIDI connector.
Then link that MIDI connector to any of the following components:
MIDI Aftertouch
MIDI Control Change
MIDI Pitch Bend
MIDI Splitter
MIDI Mono
which all output Integer values.
The 'Sysex to String' component will obviously output String values.
Here's a brief example where my keyboard controller is sending Control Change Message # 74 with a value of 15 (everything is in base 10):
Make sure your USB attached keyboard is recognized by FlowStone.
This can immediately be seen in the list of connected devices in the MIDI IN component.
'Hope this helps.
AnthonyTower
Users browsing this forum: No registered users and 51 guests
