OS version module
OS version module
Postby DSP » Sat Jun 23, 2012 7:16 am
Anyone know how to tell what OS your exe is running on (XP or Win7 ?)
DSP
Re: OS version module
Postby fixstuff555 » Sat Jun 23, 2012 2:17 pm
GetVersionEx API? Is this available to add in Flowstone? the dwmajorVersion and dwMinorVersion can display windows version...
fixstuff555
Postby Morph » Sat Jun 23, 2012 6:03 pm
Here's a solution although it is not thoroughly tested.
OS_finder_Mo.fsm
(1.5 KiB) Downloaded 1068 times
Morph
Postby Embedded » Sat Jun 23, 2012 10:10 pm
Here's some Ruby code that seems to work:
OS Version.fsm
(274 Bytes) Downloaded 1053 times
Embedded
Postby DSP » Sat Jun 23, 2012 10:11 pm
thanks all, that should get me going...
DSP
Postby RJHollins » Thu Oct 31, 2013 8:48 pm
Might someone expand out the 1st example [using PRIMS] to include Win 8 ???
OS_finder_Mo.fsm
thanks
Postby Mo » Thu Oct 31, 2013 11:20 pm
Here is an update. I have not tested it with Windows 8 yet.
OS_finder2_Mo.fsm
(1.54 KiB) Downloaded 1029 times
Mo
Postby RJHollins » Thu Oct 31, 2013 11:26 pm
Hi MO !!!
Where ya been ?? Hope all is well !
But not so well with this update unfortunately :| This one doesn't identify mine. The field is blank, the internal selector pointing to 1st S position [no input connection].
Postby Mo » Thu Oct 31, 2013 11:56 pm
Yep, hope to have more time for FS soon.
Ok, maybe it was optimized too much. Here's a new update to try.
OS_finder3_Mo.fsm
(1.56 KiB) Downloaded 1043 times
Mo
Postby RJHollins » Fri Nov 01, 2013 12:09 am
Three is a charm ... at least on XP :D
Thanks MO ... maybe guys with the new-fangled OS's will give it a running report.
confirm: Win XP
Hope you find time MO !!
Thanks 8-)
