Roland VP-550
Roland VP-550
Not only did I not know that this Roland piece existed. I also would never have dreamt that a vocoder could sound so fantastic! So warm and natural!
Martin went in a similar direction with his MIDI Choir (or was it the other vocoder synth?), so Martin, I beg you, please put your magic to good use and recreate this sound!!!
https://youtu.be/LxSe9keoWAc
Re: Roland VP-550
The Roland V-Synth has the same engine in its Vocal Designer expansion card. Its the same engine as in the VP-550, except you can tweak the controls, the VP-550 are only presets.
- adamszabo
Re: Roland VP-550
SORRY: 32 bit only for now!
Hi tulamide,
Did you ever play with my VOCODER? It can work in either midi or a manual mode. To use it in manual mode press the "Test Note Start" button till you get a waveform displayed on the scope. Set the presets for "pitch tracking" and play with the "pitch tracking" settings and also the "freq bank range knobs".
Let me know what you think.
Have fun!
Later then, BobF.....
P.S., If anyone would like to made a new fancy GUI for this I would really be grateful.
Hi tulamide,
Have fun!
- BobF
Re: Roland VP-550
@Bobf
I was trying to open , using the Alpha though and i get a "Schematic Load : type (0) not found.
Just a heads up if its also not working for the 32 bit version.
lalalandsynth - Posts: 600
