Tags not showing up
Tags not showing up
Can't believe I'm having toolbox issues again !
Was working away on a project (3.0.6) and suddedly all the stock toolbox categories (External/Element/Maths,etc. went empty. Everything still in the toolbox, but only are visible with no tag selected (the huge, long uncategorized/tagged list, when no tag is selected). So I saved my Tags/Modules folders to external location; uninstalled FS; re-installed, then all the stock parts showed up in their appropriate Tag categories, but now of course none of my custom modules or tags were present, so I copied the saved Modules/Tags folders to the FS Applications folder, now all my custom modules are there, but not the custom tags; they only show up when no Tags are selected. So I copied the saved Tags folder to App Data, but they still don't show up.
Re: Tags not showing up
Actually. I just fixed this by referring to my saved Tags folder, and just re-entering the Tag names into to toolbox, and everything moved to their correct locations.
It's most probably due to a combination of keys pressed over the toolbox.
I don't remember what shortcut I was pressing.
Now I am doing backups from user\AppData\Roaming\FlowStone\Modules and user\AppData\Roaming\FlowStone\Tags twice a month.
josevo - Posts: 33
