Append array indexes in ruby?
Postby kortezzzz » Wed Sep 28, 2016 3:01 pm
Is there any way to append array indexes in ruby?
My arrays:
array 1:
red
green
white
array 2:
tomato
frog
snow
I would like to get at the output :
red tomato
green frog
white snow
I guess the comma between the indexes in the final result should be also defined in the ruby code, so would be nice if we could add a 3th input in to this ruby code which would define the comma.
For instance, if the string comma input would be "@", the final result would be then:
red@tomato
green@frog
white@snow
People, it would be even nicer if you post your answer as a code as well. Take into account that most of us are not reasonable coders :)
Thanks!
kortezzzz
Re: Append array indexes in ruby?
Postby KG_is_back » Wed Sep 28, 2016 3:32 pm
output @array1.zip(@array2).map{|p| p.join(@comma||"")}
This one is a one-liner...
Postby kortezzzz » Wed Sep 28, 2016 7:34 pm
Thanks KG!
One liners are the best 8-)
kortezzzz
