ADSR Behaviours
ADSR Behaviours
Postby TeslaTronik » Fri Sep 30, 2016 1:16 am
Hello all,
Can you please try and help explain the ADSR Behavior to me i,m using the standard one from flowstone 3.0.9 beta 1, i am running a wave player into the ADSR as normal but no matter what i try i can not get the envelope to reset with the desired shape.. i want the release to be long (50%) and the attack to be short (0%) decay and sustain both at 50% but when playing notes in quick succession the attack will always return to anything from 0 to 50%. i have used vsti and messed around in synthmaker and flowstone for a long time now and still have never been able to find a way around this behavior.. is this a normal behavior? i would have thought that the attack would slowly come back in upon pressing a new note.
ps.. in the midi to poly i have the voices set to 1 and "retrigger new" checked and in the ADSR env "hold" and "smooth retrigger" is checked.
i hope i have explained my problem clearly enough for you to help me.
thanks, Alan.
TeslaTronik
Re: ADSR Behaviours
Postby kortezzzz » Sat Oct 01, 2016 6:57 pm
Hi Alan,
I've attached 2 lovely examples of well customized ADSR's that have been shared at the forum some while ago by MyCo and Nubeat7.
Hope it helps :)
(ADSR EXAMPLES).fsm
(247.68 KiB) Downloaded 989 times
kortezzzz
Re: ADSR Behaviours
Postby TeslaTronik » Sun Oct 02, 2016 2:30 am
Thank you very much :)
i have tried both of these, they both give the same result.
when pressing rapidly a key on the midi controller, (with a long release) and the attack set to 50%, the attack will always get sharper (shorter) and will not keep its intended shape for the envelope.
i guess this is just a bi-product of having a fast sloping pitch curve before the osc and adsr?
Thanks again. Alan.
TeslaTronik
Re: ADSR Behaviours
Postby kortezzzz » Sun Oct 02, 2016 4:09 am
I really don't know :roll:
Maybe you would like to upload your schematic, so we can hear the problem?
kortezzzz
Re: ADSR Behaviours
Postby Spogg » Sun Oct 02, 2016 9:33 am
The behaviour of an envelope ADSR is, I believe, modelled on analogue electronics principles. These use a capacitor charge/discharge for exponential slopes or use a capacitor–based integrator for linear slopes. In this way if you press a key while the envelope is still non-zero the Attack phase will start from the charge value of the capacitor and not from zero every time.
If you deselect smooth re-trigger (where available) and set the MIDI options for re-trigger etc. appropriately, you’ll get a reset effect but the result can be harsh, due to a sudden step in the envelope signal. This is more noticeable when you have a very short attack, long delay, high sustain and long release times and depends where in the ADSR cycle you are when you press the next note.
Hope this helps…
Re: ADSR Behaviours
Postby TeslaTronik » Sun Oct 02, 2016 7:46 pm
thank you Spogg, that's a perfect explanation of why it is behaving in the way it is, i guess i will have to accept that behavior as a "given".
@ kortezzzz: the schematic is extremely messy i'm afraid, but the idea behind it is a 808 emulation, but i wanted the option to have a slow attack as i find i tend to fade in wav sample 808 drum and add my own attack/transient as a layer.
TeslaTronik
