Drawing GUI Out of the plugin
Postby Wassaka » Fri Oct 14, 2016 3:07 pm
Hi, I am trying to draw a GUI but out of the plugin interface. I dont know if you are understanding me :lol: But here is an example:
As you can see, the plugin is massive and the red part is drawn out of the plugin (acting like a pop-up)... Is this possible to make in FlowStone?? Thanks (and sorry for my bad english)
Wassaka
Re: Drawing GUI Out of the plugin
Postby DigiTonix » Fri Oct 14, 2016 3:28 pm
Hi Wassaka! :) Look this...
Plug-in About.fsm
(8.23 KiB) Downloaded 994 times
DigiTonix
Postby Nubeat7 » Fri Oct 14, 2016 8:42 pm
this is not possible, you only have one fixed sized main window for your plugin..
the only thing you can do is to call windows popup windows for warnings or info..
Postby adamszabo » Sat Oct 15, 2016 12:04 pm
yes its possible. if your image/module that you hide is different size than the main plugin you can shill show/hide it with the view
adamszabo
Postby Spogg » Sat Oct 15, 2016 12:18 pm
Surely this can only be achieved if the popup window is smaller than the main VST plugin window...?
Postby Nubeat7 » Sat Oct 15, 2016 4:04 pm
yes you can create a window inside the plugin, also move it around, but only insidse the plugin window!
Its not possible to create a window outside of the plugin window!
(except windows system specific message boxes, which you can call with the win32api)
