drum pads
drum pads
Postby scanz » Tue Oct 18, 2016 4:41 pm
got a couple of queries regarding drum pads. in the drum pad test A fsm I would like to know how to make the folder selector work instead of the load button which is connected at the moment. when I link it up it keeps reopening the selected folder over and over without loading a new wave file. also in the machine spogged 2 fsm I'm trying to get the detuner/transposer to work but it just causes distortion. wondered if anyone could figure these issues out.
machine -spogged 2.fsm
folder select problem
(115.16 KiB) Downloaded 929 times
drum pad test A.fsm
detune problem
(99.49 KiB) Downloaded 878 times
scanz
Re: drum pads
Postby kortezzzz » Thu Oct 20, 2016 4:54 am
"machine -spogged 2.fsm"- The problem was the using of the pitch output from the midi to poly instead of using frequency output+turning on the boolean switch inside the counter module which connects the the manipulated frequency to the "PreciseCounter"module.
About the drum pad test A: You should combine a preset manager in this schematic or it would never save the last settings and keep opening the same folder every time.
(machine -spogged 2_fixed).fsm
(117.86 KiB) Downloaded 953 times
(drum pad test A fixed).fsm
(104.38 KiB) Downloaded 908 times
kortezzzz
Re: drum pads
Postby StereoSpace » Sun Nov 13, 2016 1:35 am
Wow! Thanks!
GUI designer
StereoSpace
