drum machine
drum machine
hi to everyone on the forum. been working on this sequencer/drum machine and it's just about done but I thought someone on the forum might be able help me out with it. the sequencer part was built by billv and kortezzz so many thanks to them and also loopytunes for the drum pads that it's based around. I would like to know if anyone could vst it and try running it in a daw to see if all the controls can be automated. I've tried it in mixcraft seven pro and the automation works fine but I,ve yet to test it with a midi controller. I asked kortezzzz if it could be made to play a two bar pattern as opposed to one bar and he recommended asking the flowstone gurus out there. it isn't that important as kortezzzz had the foresight to make it so it can run inside or outside of a daw, so inside a daw you can make it play any pattern length by just using a two bar midi clip or however many bars you want but I just wondered if it would be possible.thanks
(sequencer test )A1.fsm- work in progress.
- (1.66 MiB) Downloaded 922 times
scanz - Posts: 12
Re: drum machine
When i right-click for - midi learn - on a drum pad, i just get the load wave dialog box. within F.S. I have not tried in Cubase yet.
http://soundcloud.com/teslatronik Drop me a comment
TeslaTronik - Posts: 35
