Question About Converting from Flowstone v3.0.8.1 to v3.0.6
Postby tiffy » Sat Apr 17, 2021 5:14 pm
I have a fairly large schematic which I want to convert from Flowstone 3.0.8.1. back to v3.0.6 pebble.
Must I rebuild the whole schematic which was originally done in Flowstone v3.0.8.1 from scratch in Flowstone v3.0.6 or can you export it as is from v3.0.6?
I tried the latter option already, does not work. Both my laptops display an error message "out of memory" but on the one laptop, I have 16 GBytes RAM and the other laptop 32 GBytes RAM. This only occurs when I tried to export the schematic from Flowstone v3.0.6 but in v3.0.8.1 there is no such problem.
Any advice to help is welcome.
tiffy
Re: Question About Converting from Flowstone v3.0.8.1 to v3.
Postby adamszabo » Sat Apr 17, 2021 6:20 pm
I dont think you can save them backwards
adamszabo
Postby tulamide » Sun Apr 18, 2021 12:22 am
Backwards is not possible. But, you might have a good chance at copy/pasting from one to the other. However, try that in smaller chunks, as I'm not sure how changes in prims are handled when copied between versions.
Postby Spogg » Sun Apr 18, 2021 8:09 am
I may have misunderstood the problem, but I wonder why you want to do the conversion to 3.06 if you can export the VST from 3.08.1 successfully.
The reason for wanting to do this may be relevant.
Postby tiffy » Thu Apr 22, 2021 12:31 pm
Quote: "I may have misunderstood the problem, but I wonder why you want to do the conversion to 3.06 if you can export the VST from 3.08.1 successfully. The reason for wanting to do this may be relevant."
The reason being as I was informed by Tulamide: "And don't use 3.0.8.1, it is a bugged and slow version (for example, Ruby only runs at half speed)".
tiffy
Postby Spogg » Fri Apr 23, 2021 7:10 am
tiffy wrote:Quote: "I may have misunderstood the problem, but I wonder why you want to do the conversion to 3.06 if you can export the VST from 3.08.1 successfully. The reason for wanting to do this may be relevant."
Fair point! :lol: :oops:
