Help with serious problem
Hello gang,
I have a serious problem! All of a sudden the other day many of my older fsm's started giving me this error message " Attempted to access an unnamed file past it's end." and will not open via Fl Studio/Flowstone 3.08 or standalone Flowstone 3.09.
Does anyone have any ideas on how to fix this or what causes it?
Thanks in advance, BobF.....
- BobF
Re: Help with serious problem
This might be a registry issue.
Are you testing the new alphas on 32 bit or 64 bit Windows?
I ask because the registry switching files that MyCo provided are only valid for 64 bit. They reference
C:\Program Files (x86)
which is where the FS files are on a 64 bit system only.
Use Regedit and locate the Flowstone installation path (search for Flowstone and check the keys).
Also make sure you have the correct Ruby library installed for 3.081
I think this was a problem with one of the alphas. If you saved the file with that alpha you have to download another alpha and resave it to remove that error. I dont remember which one it was though
- adamszabo
