Delay Compensation
Delay Compensation
Hi, I want to send "Delay Compensation" to my host (FLStudio12) but the primitive module doesn't work... Any solution??
Thanks!! (I tested it in an exported plugin and DlyComp dont work
- Wassaka
Re: Delay Compensation
I can only speak for Reaper and it does work in that DAW. Maybe it relates to FLS.
You can download Reaper for free and test it maybe.
Hi there.
Are you using the standalone version of Flowstone or the FL version?
The primitive works fine in my experience BUT Flowstone is no longer supported in the most recent versions of FL Studio, so that may be your issue. I use FL Studio version 12.1.3 with the FL version of Flowstone 3.0.7. Any later versions of FL or Flowstone have issues.
- Perfect Human Interface
Perfect Human Interface wrote:Hi there.
I am using Standalone (3.0.8.1) and FLStudio 12.4 and it doesn't work
- Wassaka
I checked it and it works just fine. If you have the delay compensation in the exported plugin, and you assign it to a mixer track, and Automatic plugin delay compensation is on, the other mixer tracks will get the delay from your plugin and assign it to the other tracks.
- adamszabo
