Ruby Input Connector Names
Hi Guys
Do any of you Ruby wizards know.. is it possible to parse the names of the input connectors to generate a hash as in the example below, a bit like map.with_index but map.with_names instead?
I hope this is self-explanatory!
Thanks in advance
Dave
Thanks in advance
Dave
DaveyBoy - Posts: 131
Re: Ruby Input Connector Names
Yes, it is. Ruby knows the symbol method to_sym.
"this".to_sym # :this
Be careful not to use it on dynamic data, because there is no garbage collection on such generated symbols! (You would create the famous "memory leak")
Hi Tulamide
Thanks for the swift reply
perhaps I didn't explain very well
What I actually meant was can we 'extract' the names from the Ruby edit automatically.
In the example if I add another input, hash 'a' is automatically updated with the index but I want to use names for the keys not integers, doesn't matter if they are symbols or strings. Hash 'desired' is just an example of the result I'm after.
Hope this explains it better
Input Names.fsm- (456 Bytes) Downloaded 936 times
Haven't downloaded the example yet, but based on your description I'd say it is possible, but more complicated. The only way I am aware of to get the name of the input as a string is via the RubyEditConnector class. This class is provided only in the event method. You'd basically have to trigger each input via
(or externally) and build the Hash one by one using the event method
I hope that helps you more?
input index, value
def event i, v, t # i = RubyEditConnector, try i.to_s.to_sym or maybe even i.to_sym
Hi Tulamide
I'm not sure I'm understanding you correctly, do you mean like this:
I'm relatively new to Ruby so please be gentle with me
Any chance you could post a simple example?
Thanks again
Thanks again
Got it
After reading Trogg's excellent API Docs, should have looked there first
Thanks again anyway Tulamide, you pointed me in the right direction, very helpful as always
Input Names - Working.fsm- (1.05 KiB) Downloaded 923 times
I was about to go out and didn't want to leave you without an answer. So I tried it from my head. And your final result looks exactly as I imagined it. I just forgot about the 'name' method, and I'm sorry for that. Luckily, you were able to help yourself. Well done!
