Copy/Paste Array.
Copy/Paste Array.
I am working with the advanced envelope , it has 4 states for the envelope setting which you can load and save.
I would like to be able to copy the setting from one to another. - copy from 1 to 4 for example.
It seems like I should be able to to hold the array in ruby until it gets a trigger (copy), then its ready to paste , either with a dedicated paste button or just an automatic paste when you hit "copy" - when on 1 for example and then push 4 .-, thereby pasting it into 4.
The automatic paste would suffice , but I guess it would be better to have a dedicated paste button, so you can flick through 1 to 4 and select the one you would like to paste over. Seems more intuitive that way.
I am a complete noob in Ruby but I am trying to learn.
So far I can get the array into Ruby and send it onwards , but I need to set two conditions as far as I can tell , a trigger that says I want to send it forward (copy) - but if and only when I select one of the 1-4 switches or hit another trigger (paste)
Unless I am missing something that should be enough if I send this array back into the preset setting, everything should also save and remember everything properly.
Any thoughts ?
Any thoughts ?
lalalandsynth - Posts: 600
Re: Copy/Paste Array.
This was simpler then I thought . Solved it seems , just used Ruby and triggers.
Seems to work.
Edit..spoke to soon , I can copy and paste , but i need to be able to plug it in correctly.
Edit... and it seems to work properly , I replaced the load and save with copy and paste , and use a preset manager to save all 4 envelopes instead.
Seems to work.
Users browsing this forum: No registered users and 31 guests
