Multiple inputs/sidechain question.
I am setting up a plugin to have a sidechain input - doing this in Reaper.
So I set it up so that the plugin has 4 inputs, assuming that will work.
When I open the plug in Reaper , I make 2 tracks , #1 for the plugin and #2 for sending audio into the sidechain of that plugin.
I make a send from #1 , sending audio from that track ch1-2 to ch3-4 on #2 like I always do when routing into sidechain on other plugins.
However , it seems that when I do this , some of the signal always leaks into the 1-2 of track #1 , so rather then going into the sidechain , it goes into the plugin and is processed.
The 4 channels are completely separate and this works in FS , what might I be overlooking here , or does FS not support multiple inputs /Sidechains ?
lalalandsynth - Posts: 600
Re: Multiple inputs/sidechain question.
Nvrmnd , operator error
Yeah I had this issue when struggling to configure my Quilcom Bluesky vocoder into Reaper. Not very intuitive.
Glad you got it sorted anyway.
