HOM file dilemma
HOM file dilemma
Postby rocknrollkat » Mon Oct 09, 2017 10:54 pm
Hello again,
I still have not been able to load Spogg's HOM files into Flowstone 3.0.2.
I put them in the user folder, FL doesn't see them.
Once again, any help would be appreciated.
Bill P. ;)
rocknrollkat
Re: HOM file dilemma
Postby BobF » Mon Oct 09, 2017 11:24 pm
Hello rocknrollkat,
Ok, an easy way to do this is open up Flowstone and select Toolbox. Then select, Open Modules Folder. Next open the User folder. You can cut and paste your hom's here from wherever you have stored them. Once you have pasted them inside the folder, close Flowstone and then re-open it, the hom's (modules) should now show up.
Good luck, BobF.....
BobF
Postby rocknrollkat » Tue Oct 10, 2017 2:15 pm
Hello Rob,
I tried your method, no dice.
I gave the file a very unique name so I could search for it, no good.
I have also created a 'user' file with ONLY the new homs in it, renamed the original user folder so Flowstone wouldn't see it, Flowstone still loaded the factory homs !
I'll keep trying and post my results.
Thanks for your timely reply !
Bill P. - rocknrollkat ;)
rocknrollkat
